Data Issues
hf123
Hi,
I have a Samsung galaxy mini with 108.9mb of internal storage and a 4gb sd card, i have only got 8.85mb space left on my internal storage and i can not free any space up, i've uninstalled or moved all apps to sd card and cleared data and cashe for all of the apps left using app2sd. Please help me! Thanks in advance!:)
Hello and welcome aboard.
I have that same problem too. Even though I have X amount of available space.. I can't seem to install X amount of mb.
I found that there are two ways around this: replace the sd card with a larger one or uninstall all installed applications _remove and reinsert battery _ then install all the larger apps first.
Good luck. :)
There are others, but that’s the only one I’ve noticed making an appreciable difference.
Now that you have free space, you might try something like History Eraser to clean out the crud, that might free up even more.
