elwin15208
Member
Greetings, all - I have recently had this message appear twice on my S3:
Beneath it sits a "Reset device" button. I have not pressed it. Instead, each time I have turned the phone off and turned it back on. Each time, the message has disappeared, and the phone has continued to function normally as before (apparently, at least).
Questions:
1 - Does "data partition" refer to a partition on the phone's internal storage, or on my micro SD card?
2 - What might be causing this message, and how might I prevent whatever is happening from happening?
TIA...
Device memory damaged. The data partition has been corrupted. You need to reset your device to factory defaults. This will erase your data
Questions:
TIA...
