Data Scanner - Barcode Scanner/Database Solution (Hopefully Images Work this Time)
In my last post about Data Scanner the images did not come through correctly. I'm going to try again.
Application Name: Data Scanner
Category: Business
Cost: $.99
QR Code for Data Scanner on Google Play
Data Scanner Main Screen
Description: Data Scanner provides businesses with a customizable barcode scanning solution. Data Scanner saves barcode values as well as date/time of scan and location (longitude/latitude) of each scan. Once the data is scanned it can be displayed on the main screen. It can also be exported to a text file. Finally, there is a .NET class library on our website which allows .net developers to create their own custom applications to process Data Scanner's export files. Data Scanner provides a Settings Screen which allows users to customize many things: type of barcode to recognize, which scans to display, how the scanner operates, export options, etc.
Check out our website: Pine Point Mobile Solutions
Data Scanner is sold on Google Play.
