Data traffic disable short cut
peko123
Hi!
I've got Galaxy Ace (5830i) with Android 2.3.6 and I would like to know if there is some kind of short cut for enabling/disabling data traffic (like it was on 2.3.3 by holding on/off button)?
Thanks!
Hi!
Thanks!
it is still there in 2.3.6 just select the "Data Network mode" by long pressing the power button.
There are widget applications like widgetsoid on the play store that you can use, create a widget for network data and put it on your home screen.
