exitwounds8o8
hey guys
any one having issues transferring data from your handset memory onto an sd card?
I have a 64 GB sd card and when i try to move files from the handset to the card the vast majority of the time the files get lost in cyber space. (literally)
they no longer appear on my phones memory and they either dont get transferred to the sd card or the file partially transfers but doesnt complete.
for example if i download a music album and try to transfer it a handful of songs just simply vanish once the transfer is complete. or if i move a video file from the phone to card a lot of the time the file wont completely transfer so ill get maybbe 5 mins or so of actual playback before the file ends.
I have checked these files prior to transferring and they all worked fine on the phone its just when i try to transfer them that i run into this issue.
also does anyone know of a way to get files to download directly to the card and not the phones memory?
i find it odd that i cant manually select the download path when i try to download files.
any help in these regards will be much appreciated.
Thanks!
Thanks!
