Data usage and call usage info
Joey76
Member
Hi guys,
My old man is having problems with Virgin Mobile Aus with his call credits and data usage.
A quick flick through the internet finds he is not alone.
Im not sure if this is an android thread or galaxy s2 thread but what I would like to know is....
Is there a way for him to check his "calls made" minutes and his "data used" per month.
I had an iphone and Data Usage was very easy to check.
Virgin do not accept 3rd party apps to do this either.
Is there a way either through the android system or Galaxy s2 phone to have a clear way of finding out for example...
you have made 325 minutes so far this month
you have used 1.3 gig of data
I would really like to try and have a guide before what I see as a big problem in the future with this carrier.
Thanks for the help
You can check the data used by going into Settings > Wireless & Networks > Data Usage
I really do not think there is a way to monitor your minutes unless you get an app.
