Help DDMS not working under Win7 64bit
Bolec
Well it is actually more windows related problem I believe. I have Windows 7 Home Premium 64 bit version and I can't get DDMS to work. The 0.5sec popup says that it can't find the JAVA. It is searching for it in C:/Program Files/Java, mine is/was installed in Program Files (x86). I reinstalled JAVA installing it to program files, but the problem hasn't fixed. Any ideas? Is there a way to run ddms under 64 bit operating system?
Beuler Beuler?????
you try installing the 64-bit jdk not just installing the 32-bit in ur other folder lol? that was my problem. but now ddms wont find my phone
