Help Dead AGAIN!
AAEBoiler
Well, my N7 (first generation) is dead again. It died back in June some time after 4.2.1 came out - it wouldn't boot past the "X", wouldn't boot into recovery mode, etc. So, ASUS had me send it in and the "fixed" it.
On Friday I went to install 4.3. My N7 started to reboot then the screen with the Android lying down came up. Unfortunately, it didn't have the rotating "thingy" as in the past, I just had the Androig robot lying on his back with a big red triangle saying error above his open belly. Then, my N7 went into an endless reboot cycle never progressing past the "X" screen. I did a live chat with an ASUS rep and they're having me send it in again.
I'm super frustrated as I've had this table for 8 months now and I've lost 2 months due to system failures. At this point any money I've saved from choosing this table versus and iPad mini is being squandered on shipping charges to send it in for repairs!
I would do a system reset. Boot into recovery and wipe the data. You should be fine then. You lose your info though unless you have a backup. Wugfresh also has a toolkit that should get you past the bootloop.
Are they repairing it or swapping it out?
Sounds like they simply flash a stock image and send it back, you can do that yourself with Wug's Nexus root toolkit.
Insist they replace it.
