Debug opens when clicking on a spinner that is connected with database
santhoshp
My simple application has a spinner in which i updated some datas from database. When i click on the spinner debug opens. My code for loading spinner is below and i attached the screen shot of the Debug opened. I am using Windows-OS, Eclipse 3.5 , Android API-8
//Open a database
db=SQLiteDatabase.openDatabase("data/data/com.android.layout/MyStorage", null, SQLiteDatabase.CREATE_IF_NECESSARY);
db.beginTransaction();
//Desired column to be loaded from DB to spinner
String[] columns = {"username"};
Cursor c = db.query("tbleprof",columns,null,null,null,null,null);
startManagingCursor(c);
//Take a vector to hold the values from database to an array
Vector<String> values = new Vector<String>();
while(c.moveToNext()){
//Add elements to the Vector array
values.addElement(c.getString(0));
db.endTransaction();
//Copy the Vector to a String array so that it can be given to the adapter to load the data to spinner
int length = values.size();
String[] valuesForSpinner = new String[length];
values.copyInto(valuesForSpinner);
//Configuring the Spinner
ArrayAdapter<CharSequence> spinnerAdapter = new ArrayAdapter<CharSequence>(getApplicationContext(), android.R.layout.simple_spinner_item);
spinnerAdapter.setDropDownViewResource(android.R.layout.simple_spinner_dropdown_item);
spinner.setAdapter(spinnerAdapter);
//Adding elements to the adapter from the String array
for(int i = 0;i < valuesForSpinner.length;i++){
spinnerAdapter.add(valuesForSpinner);
} catch (Exception e) {
// TODO: handle exception
e.printStackTrace();
}finally{
db.close();
