Have you done any coding? Everything's easy when you're a spectator.Surely they would be quite esy to do (done right).
Can't be good for your battery life, though.I personally use Turtle Photoframe. It has some nice features including allow you to set a frame to a folder and then rotate through the images at a set amount of time. It's simple and had everything I wanted. May not be for you but it's my fav.
And if you run it while on a charger... then you might as well get a real digital photo display, with 5 times the image size of your phone's display or more, that you don't have to remember to unplug and take along all the time.
