Root Default HELP!! Restoring phone back to stock
So here is my problem
Phone:LG Optimus
MODEL: P509
Carrier: T-mobile
Description of problem:
Phone was once rooted via Z4 Root,super user & titanium backup method.
1. Phones was unrooted & All of the above programs removed.
2. Factory Data Reset.
3. Poped in new sim phone works
4. Go through new phone setup, Intro wizard crashes, If i do not turn it off, the phone will receive calls & texts, but will not hang up and gets stuck on a black screen with Connectivity info bar still working.
5. If you pull batter & restart phones loads and makes all usual sounds but gets stuck at android screen and never loads
5. ROM Reset via Home, Volume down, & power key will work but also will start the "new phone setup" and will repeat if once the intro wizard launches.
What Should I do, I need this phone asap for my mother as i just ****ing broke down and drooped the $600 on a GS II.... Which i love
