C charlyee Android Enthusiast Dec 9, 2010 #1 Anyone using the default keyboard on 2.1? I just tried it and it seems to be easier than the HTC_IME Mod that I was using. However, I do not have the haptic feedback even though it is checked. Anyone tried it? Any solution? Thanks Much
K kauvio Newbie Dec 9, 2010 #2 do u have the "vibration on keypress" checked? the vibration is very weak though compared to the android keyboard.
C charlyee Android Enthusiast Dec 9, 2010 #3 kauvio said: do u have the "vibration on keypress" checked? the vibration is very weak though compared to the android keyboard. Click to expand... Yes I do. maybe the fact it is weak is the problem. Thanks
