Help default location for installed apps?
joemonkey
when i install app from droid market, are they install to the phone or the SD card. if to the phone, do i have the option to put them to the SD card?
when i connect the x10 to my computer via the USB cable, i don't seem to see the apps. where, which folder rather, do they reside?
you can only be installed to the phone mem, but when 10 gets android 2.2 they can be installed to the sd card......
But right now you cant. Only with root you can use apps2sd i mean but some files still gets to phone mem
