Anyone know the default lock pin for the Wildfire S?
I mean, the one you get in Settings > Security > Set up SIM card lock
So you have to enter a code when you turn the phone on. I understand that's set by htc rather than the network.
Not the one to access the sim card or to unlock a phone thats locked to a network.
I've changed sims and stupidly pressed yes to reset all the data; the previous lock I had no longer works and I'm down to my last try
Thanks
Thanks
