Hi all Just purchased a san francisco and loving it! Everythings been going fine and running smoothly, But is there a way of choosing your SD card as the default memory ??? Once i have a few apps and games installed i start getting low memory messages Please help if you can.
Not sure if you can unless you flash it with one of the custom 2.2 ROMS out there as installing to SD Card isn't an option with 2.1. There's an app on the market called App 2 SD but I've never used so I can't confirm if it's any good.
If you want to flash to a newer version of Android, take a look here or do a search on here for other instructions. I've not done it myself yet, but will give it a go at some point in the week.
