Help Default notifications
  • Thread starter Thread starter Note 5 question
  • Start date Start date
N
Note 5 question
Guest
Notifications on my Note 5 wouldn't stop going off. I didn't know which apps were causing this so I changed the tones to all of my apps. I have discovered that it's my "default notifications' that keep going off. How do I turn these off?
Default notification is a tone, not an app. It just means that you haven't found the app that produces it yet.
If you can spot a pattern to when it happens that would help, but it can be tricky if it's something obscure (I once had a battery monitor making a notification sound when the cpu temperature exceeded some threshold, which took a while to work out).
I assume you are just hearing a sound? If there is an actual notification in the notifications drawer then a long press on that will let you see what app is producing it.
