jeremy1701
Hello,
All of my default sounds are missing. They only sounds I have are the ones that have been downloaded from HTC Hub, those appear on the SD card. I don't think I did anything to remove them. I've tried the restart and the battery pull trick, no luck. I have them on my old Inspire, anyway I can snatch them off that and put them on the new one?
