toddpedersen
So I am loving my E3D overall, but just came across something that I thought was odd and I am hoping there is a fix.
Under the phone settings you can enter a default text message that gets send when you get a call and press the menu key and select Send Message.
That works fine and well when you phone is active (Not Locked) when you get a call, but if your phone is locked with either the normal lock screen and or the pattern or password lock, you do not have the ability to bring up that Send Message choice because you have to first either answer the call or decline the call, both of which are not an ideal situation. Is this a glitch that needs to be reported to HTC or am I spacing out and missing something easy here?
this is grossly OT and i apologize, (this tickled me so...)
