Default USB mode?
GregwGA
Is there a way to configure a default USB mode for my phone. Everytime I plug my phone into my computer or car charger, a screen pops up and asks me to select a USB mode: media sync or mass storage. All I am trying to is charge my phone so I usually exit from this screen.
Is there a way to eliminate the displaying of this screen and select a USB mode manually when I want to or is there a way to specify a default USB mode
I remember this behavior a while back but it got removed with a firmware update. I can't remember which update changed this behavior but the phone now remembers a default USB connection mode. So if you set it to mass storage mode that will be it's default.
What firmware are you on? You should look into updating your phone.
Ray.
