defaulting to clean slate scenes
i am trying to access a saved scene that i created. whenever i go through the processes of finding it, menu-->settings-->personalize-->scenes, and select my saved scene when i press home it takes me back to the default clean slate scene. if i then navigate back to the scene selection it shows that i hadn't changed my scene at all and clean slate is still selected.
i am unable to created a new custom scene, each time i navigate back to the scene selection it always shows that i have selected clean slate.
in the past i have been able to scroll from scene to scene, from custom to the android defaults, without any issues.
does anyone know how to fix this? any help would be great.
i have a droid eris.
thanks
I'm not sure what the problem is, but you could save yourself a little time by using menu > scenes instead of menu > settings > personalize > scenes. Goes to the same place, but the first way is a little faster.
