DEL (Delete) button not working
JunPyo
Hi Android people! My android keyboard's DEL (delete) button is not working. Didn't installed or changed something, it just happened out of the blue. I was typing a message and then there ya go, it's no longer working.
I tried to press the buttons beside it (letters M & L) and while holding the buttons I hovered above DEL and it works somehow, though not so effective. Sort of like a stuck button for physical keyboard.
I also installed another type of android keyboard, still the same problem. Right now I'm using TouchPal keyboard though this one's not so user friendly compared to stock/android keyboard.
Already 'cleared data' and 'force stop' and definitely the 'uninstall' button is disabled. Problem is still there. I'm using a ZTE Blade Android Froyo (2.2.2). Been using this for almost a year and definitely a factory reset is the worst thing to do.
Hoping for your fix ideas! Thanks!
