But not universal: I've no such problem.I think it's an issue with the most recent phone app update. Look at the reviews, a lot of people have been experiencing the same thing since the update.
I just started having this problem this week. I usually can get one call off without a delay, but the second call can take up to a minute to finally start. The only way I have seen to make it go away is to reboot, but then after the first all it starts happening again.
No I do not have that app installed.You have bleacher report installed?
I could hug you if i could.. I've been searching EVERYWHERE for solution to this. I had MLB at bat... Uninstalled and solved. Kudos to you my friend.If you have MLB at Bat installed, uninstall it. That appears to resolve the issue.
You are so very welcome.I could hug you if i could.. I've been searching EVERYWHERE for solution to this. I had MLB at bat... Uninstalled and solved. Kudos to you my friend.
Hi Folks, What is MLB at bat??
