Apps Delayed instruction?
Anza87
Hello,
I need to execute one OutputStream instruction with little delay, because may receiver is to slow for receiving second data...
Here is the example:
Code:
toggleButton2.setOnClickListener(new View.OnClickListener() {
                EditText editText1 = (EditText)findViewById(R.id.editText1);
                public void onClick(View v) {
                    if(toggleButton2.isChecked()){
                        try
                            String t = "xxxx";
                            mmOutputStream.write(t.getBytes());
                            int vrednost = Integer.parseInt(editText1.getText().toString());
                            //delay 100ms
                            mmOutputStream.write(vrednost);
                            }catch (IOException ex) { }
I wrote comment where I need delay for around 100ms...Is this possible? How can I do that?
You can simply use :
Code:
sleep (100);
In your code.
Keep in mind that if you use it in the UI thread the interface will stop responding while sleeping; a more general way to solve the problem is to use a separate thread (avoids UI stop).
