Hi there,
Samsung Galaxy S7 running Android 7.0, not rooted. Carrier is Verizon, if that matters.
Over the past couple weeks, my phone has been showing some odd behavior. It is temporarily fixed (for anywhere from a couple hours to a day) by restarting the phone, but it never lasts long. When it is in this state, here are the behaviors I've noticed:
-Notifications from various apps (Gmail, Facebook, Reddit) are massively delayed, often showing up hours after they should have. If I go into the app, it's all synced fine. It does not appear to be a syncing issue, just a notification issue. Text notifications come through immediately, as they should.
-Reminders scheduled through the Wunderlist app are also delayed, and the amount of delay varies greatly. Often an 8 PM reminder shows up at a strange time like 4:53 AM.
-The Blue Light Filter scheduler won't work. Often my first hint that something is wrong again is when this doesn't change as it should. It will either stay on or off, depending on the state it was in when my phone starts these behaviors again. The Do Not Disturb schedule, however, continues to work as it should.
-The weather widget will not refresh on the home screen. When I open the weather app itself, it will refresh within, but it will not update on the home screen until I restart the phone again.
-I wondered if it was some sort of clock issue, but the clock is always correct.
It's possible it's related to a system update (G930VVRS4BQC9) which occurred 5/23/17, however I don't think it's been going on quite that long. Does anyone have any ideas for me? All I can find on the internet is about Gmail specifically, but I am having multiple seemingly connected issues, not a Gmail app issue. I've uninstalled a couple new apps I had downloaded recently, but it made no difference. All other apps are set to auto-update.
Please let me know what additional information I can provide to help solve this problem.
Thank you!
Thank you!
