Delete home screen panels
It varies from manufacturer skin to skin. I'm not familiar with Touchwhiz, so I'll move this to the device forum and let other Note 4 owners help you out.:)
WELCOME TO ANDROID FORUMS Joey3071 !
Long press on the home screen that you wish to delete.
While keeping your finger in contact w/the screen,swipe up.
Here's a video showing the GALAXY S5,it uses the same method:
so i am an actual samsung rep at a call center. all you have to do to remove home screens is find an empty spot on your homescreen. tap and hold it and it should make the homescreen go small and then you will just tap and hold the home screen you want to remove and drag it to the trash can at the top of the screen. and if you want to change which screen the phone goes to when you press your home button all you have to do is you should see at the top of each home screen a little house, just tap on the house and that will change the screen your phone goes to when you press your home button. hope this helps!! :)
