I am new to android phone, don't know how to delete message after listening to it. I have like 15 messages that I can't seem to get rid of.
Can anyone help?
Voicemail is a carrier feature, not a phone feature. So how would you have deleted it on a dumb phone?
On my carrier pressing "3" while listening to a message deletes it, but then it also tells you that at the end of the message. I guess yours is different. If we knew what network you used we might find someone who knows (remember this is the internet: we don't even know what country you are in unless you tell us).
A text message with the voice message in it? I've not met that before, but there are plenty of ATT users in the forum so hopefully someone will know.
Have you tried just pressing and holding the message? That's the android equivalent of a right-click of the mouse, and usually is the way to select a message and bring up other options, including deleting messages. That's what I'd do with a normal text, so hope it will be the same here?
