you can't on your own. only a moderator can delete posts. you can only edit your post. but there is a "tool" function where you can make a "report" to a moderator and they can delete the post for you.
Deleting a post or a thread is available only to the moderators. If you ever want or need something deleted, just hit the report radio and request the deletion. Sometimes there is merit in leaving the post or thread to help others or to continue the flow of a thread but most often the request is honored.
I moved this to the suggestion box as it isn't android related. Yep, as mentioned, if you want a post deleted just hit the report button. So long as it won't break the conversation to terribly we'll oblige. Most times it isn't a problem. At the bottom of the post you want deleted you should see the link below:
Just tap the "Report" and let us know you want it deleted and we'll take care of it. If not, we'll let you know why.
