HeyHey dudes!please help! Iam new here,I accidentally deleted the framework of my phone running jellybean! it is stucked in manufacturer's logo, still on stock recovery.thanks in advance
Hey
As your phone doesn't have a system to run now ,its stuck on boot logo.
So you gotta install (flash ) A new system , lollipop or jellybean if it is available for your device .
Let me know the device company and model and ill get back to you with the official firmware links .
Thanks
You need a Pc thenthanks for the reply bro!
phone model is cloudfone excite 501d I already have its firmware just help how to make it back to phone
, sp flash tools , driver and your ready to go.can you please guide how to push it using adbYou need a Pc then, sp flash tools , driver and your ready to go.
I tried it but I get an error message storage mismatchThis Blog gonna help you do your work :
http://phoenixemer.blogspot.in/2016/06/cloudfone-excite-501d-firmware.html
Let me know if it worked for you and you can mark this thread as answered .
Downloaded the version 3.xx and run it as admin . Also install the Windows drivers .I tried it but I get an error message storage mismatch
Let me do some research for you and i be back in a second.Storage type mismatch! scatter storage type is hw_storage_emm target storage type is hw_storage_no
was your phone rooted? and what is the version of android your trying to flASH.Storage type mismatch! scatter storage type is hw_storage_emm target storage type is hw_storage_no
HeyCan it be pushed using adb? I read some solutions for it in xda forums
Yes ,but I don't know the commands needed ,you can flash recovery using adb or fast boot and then reboot into recovery and then using recovery flash the zip firmware .can i push framework using adb?
i read some forums that it will work please guide so i can push it using adb
Worked ? flashing cwm is the key , It would be so helpful in unbricking your device .http://forum.xda-developers.com/showthread.php?t=762422
thats the commands I found
I will tryWorked ? flashing cwm is the key , It would be so helpful in unbricking your device .
Those fastboot flashing recovery commands worked for you?
