I've been having a lot of trouble trying to figure out how to delete an item from a ListView. I saw some similar questions, though none with answers that helped me to produce a working solution.
I have a layout which includes the listview, an edittext and a button. On button click, the edittext's string is added to the listview. Clicking on a listview item opens a dialog which asks for confirmation to delete that item. When confirmation is received, the item appears to delete. But when the delete button is clicked on another item, the item deletes, but the previous item reappears in its spot. From my limited understanding, I assume that the item doesn't delete from the SharedPreferences, and so when they are loaded again, the item reappears. I've tried clearing the SharedPreferences before saving after delete, but this didn't help (though I could've been doing it wrong).
I've included the whole class incase anyone has time to test it out in their IDE. I understand there are a lot of unneeded objects and the code is quite messy which is a result of me screwing around with the code to try and get this to work. Though everything works as it should, aside from deletion.
[HIGH]
package com.example.send2omni;
import android.app.Activity;
import android.app.AlertDialog;
import android.content.DialogInterface;
import android.content.SharedPreferences;
import android.os.Bundle;
import android.preference.PreferenceManager;
import android.text.AndroidCharacter;
import android.util.Log;
import android.view.View;
import android.widget.AdapterView;
import android.widget.ArrayAdapter;
import android.widget.Button;
import android.widget.EditText;
import android.widget.ListView;
import android.widget.TextView;
import java.util.ArrayList;
import java.util.Arrays;
import java.util.List;
public class ContextsList extends Activity {
public static final String CONTEXTS = "contexts_list";
EditText display;
ListView lv;
public ArrayAdapter<String> adapter;
Button addButton;
String temp_appender;
String appender = "";
List<String> dataset;
String[] splitup;
public String items;
ArrayList<String> itemsarraylist;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.contexts_list);
display = (EditText) findViewById(R.id.editText);
lv = (ListView) findViewById(R.id.listView);
addButton = (Button) findViewById(R.id.bAdd);
LoadPreferences();
lv.setAdapter(adapter);
LoadPreferences();
adapter = new ArrayAdapter<String>(this, android.R.layout.simple_list_item_1);
addButton.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
appender = LoadPreferences();
if(display.getText().toString() != null){
temp_appender = display.getText().toString();
String string_to_split = appender + "," + temp_appender;
List<String> items = Arrays.asList(string_to_split.split(","));
(getApplicationContext(), android.R.layout.simple_list_item_1, items);
adapter.notifyDataSetChanged();
SavePreferences("LISTS", string_to_split, null);
LoadPreferences();
display.setText("");
lv.setOnItemClickListener(new AdapterView.OnItemClickListener() {
@Override
public void onItemClick(AdapterView<?> arg0, View arg1, int arg2, long arg3) {
deleteItem(arg1);
protected void deleteItem(final View arg1)
AlertDialog.Builder dialogBuilder = new AlertDialog.Builder(this);
dialogBuilder.setTitle("Delete");
dialogBuilder.setMessage
("Do you want to delete \"" + ((TextView) arg1).getText() + "\"?");
dialogBuilder.setPositiveButton("Yes", new DialogInterface.OnClickListener() {
@Override
public void onClick(DialogInterface dialog, int which) {
String splitit = LoadPreferences();
List<String> listit = Arrays.asList(splitit.split(","));
ArrayList<String> itemsarraylist = new ArrayList<String>();
for(int i = 0; i <listit.size(); i++){
itemsarraylist.add(i, listit.get(i));
try {
adapter.remove(((TextView) arg1).getText().toString());
itemsarraylist.remove(((TextView) arg1).getText().toString());
try{
SavePreferences("LISTS", null, itemsarraylist);
}catch(Exception e){
} catch (Exception e) {
Log.e("remove", "failed");
dialogBuilder.setNeutralButton("No", new DialogInterface.OnClickListener() {
@Override
AlertDialog deleteDialog = dialogBuilder.create();
deleteDialog.show();
protected void SavePreferences(String key, String value, ArrayList<String> opt) {
// TODO Auto-generated method stub
SharedPreferences data = PreferenceManager.getDefaultSharedPreferences(this);
if (opt != null){
for (int i = 0 ; i <= opt.size(); i++)
value += opt.get(i) + ",";
SharedPreferences.Editor editor = data.edit();
editor.putString(key, value);
editor.commit();
protected String LoadPreferences(){
String dataSet = data.getString("LISTS", "");
dataset = Arrays.asList(dataSet.split(","));
splitup = dataSet.split(",");
List<String> items = Arrays.asList(dataSet.split(","));
for(int i = 0; i <items.size(); i++){
itemsarraylist.add(i, items.get(i));
(this, android.R.layout.simple_list_item_1, itemsarraylist);
return dataSet;
[/HIGH]
And here's the layout to save some time:
[HIGH]
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android
rientation="vertical"
android:layout_height="match_parent"
<LinearLayout
android:layout_width="fill_parent"
android:layout_height="wrap_content">
<Button
android:layout_width="wrap_content"
android:text="Add Context"
android:id="@+id/bAdd"
android:layout_gravity="center_horizontal|top"/>
<EditText
android:layout_height="fill_parent"
android:id="@+id/editText"/>
</LinearLayout>
<LinearLayout
android:layout_height="fill_parent">
<ListView
android:id="@+id/listView"
android:layout_gravity="center"
android:longClickable="true"
android:headerDividersEnabled="false"
</LinearLayout>
</LinearLayout>
[/HIGH]
I cannot express how grateful I'd be if anyone could get this to work. It's the last step I have in completing my first app.
Thanks for your time everyone.
[HIGH]
EditText display;
ListView lv;
Button addButton;
String[] splitup;
@Override
LoadPreferences();
LoadPreferences();
@Override
LoadPreferences();
@Override
deleteItem(arg1);
@Override
try {
try{
@Override
if (opt != null){
editor.commit();
return dataSet;
[/HIGH]
[HIGH]
android
rientation="vertical"android:layout_width="match_parent"
<LinearLayout
<Button
<EditText
</LinearLayout>
<LinearLayout
<ListView
</LinearLayout>
</LinearLayout>
[/HIGH]
