Help Deleting Pre-Installe Stuff
Is There a way to Delete Media Hub, and all the Amazon stuff?
It shows up in Task Manager and Application Manager but the Uninstall Button is removed.
Right now I am using an Awesome app Called Onavo Count. Which tracks my data, and I have set it to Terminate Media Hub anytime it tries to use.anything but Sufi.
I would rather just delete it.l
You can not delete those apps unless you root your phone.
Obtain Root then download Titanium Backup (or purchase if you wish). Then you can go in and Delete those files and do the Mod for the tether block.
Yep. Rooting is fairly easy with this phone, though. Just head over to Team US Cellular. You just have to flash a file in Odin, and then root using SuperOneClick.
