Depending on which device you are using your steps may vary slightly.
First you need to open your Bluetooth settings. I did this by long pressing the Bluetooth icon in my quick settings but you should also be able to get there through your phone settings. Open the settings app on your device and look for "Bluetooth" or "Connections".
Once in your Bluetooth settings you should see something similar to this:
In my case there's a gear icon to the right of the Bluetooth connection. Tap that then on the next screen choose the option "forget"
