Now that I have my phone rooted and sense able flashed is it ok to wipe all the contents from my sd card? There is a lot of remnants leftover on it and it bothers me that there are so many useless directories on it.
I had the same question not too long ago. Got some pretty good advice I copied my sd card to my comp just in case anything went wrong. make a nand backup that way if anything messes up you can just copy the contents of your card back over and restore your nand. Then, I unmounted the card from within the phone and formatted, no problems whatsoever. Some things will need to re-cache and such but everything should be fine. I got rid of almost 2 gigs of worthless crap.
