Root Delta Material CM13 Theme
Want more themes?
  • Yes
    Votes: 2 100.0%
  • No
    Votes: 0 0.0%
  • Total voters
    2
DeltaXzombies
After messing around with ThemeDIY I came up with a small theme. This theme is for people who want to maintain a stock material feel but want a blue twist to it. Just download then install. Boom, done
All screenshots plus the apk are attached
Theme includes:
  • Home/Lockscreen wallpapers
  • Themed Settings menu
  • Themed Quick settings menu
  • Themed Nav bar
Note: The settings menu opens a little slower than normal, I don't know why.
Report any bugs.
  • DeltaMaterialCM13.apk
Theme includes:
  • Themed Nav bar
Report any bugs.
I like the theme, works n looks sharp only thing is the calculator doesn't work! Thanx very much!
The stock cm calculator apk. yes it works but you can't see all the buttons like 0 & = etc. I notice ever since Ive been using this theme I get a lot of random force closes.
Weird. I don't know how to fix it since I use a app to make themes. I only have the status bar themed and haven't ran into force closes so its the style part. If you want the same type of settings menu try the hexolibre theme.
I also get random force closes and the phone sometimes reboots randomly, but that's with any cm13 theme (even ones I got from the play store), meaning it's not a problem with this theme, probably just the theme engine itself.
