Hi,
Got a Desire HD off a mate who said that the phone was getting no signal so thought as a project i would try and fix it.
He said that it worked fine and then he had factory reset it and after the phone got no signal.
I have run the ace hack kit for gingerbread and that has worked fine and now have s-off and should have simlock removed but dont know how to check but according to the hack kit should do. However when i had finished the phone still has no signal. Have tried to connect using different sims but with no luck. phone also says that it is unable to connect to the network with this sim even though i am using the correct sim!
Any help would be much appreciated, thanks.
