Help Desire HD Power Button
MrRussells
Hey, I don't know if anyone else has had this problem with their DHd but I had a hairy moment earlier. The power button on my DHD was not responding. I read a few forums and apparently they get stuck now and then. I decided to get a small glasses screwdriver and gently flicked the button with it, this made the button pop back out.
This may be a com in problem just thought I would share my experience.
MrRussells
same thing happened to me. took battery out, fiddled with power button and blew some dirt out then put battery back in, seems to be working now. its prob cos i've dropped it several times :/ i've cracked the lcd screen in two places although the front glass panel is fine, great fone but not very durable screen, so easy to crack
The power button on my DHD suddently became irresponsive, so I thought it got stuck or broken. I spilt some milk on it and thought that might be the reason for the fault.
My DHD is running Android 2.3.5
HTC Sense 3.0
Software number 3.12.405.1
Symptoms:
1. The screen lights up randomly by itself and the phone doesn
cheers for the tips dude, think this happened to me only one on my old DHD before the whole unit got replaced
I've exactly the same issues as described by Cookie57. Unfortunately, leaving out the battery for 6 hours didn't help to solve the problem.
Although my desire hd been through some repairs (new lcd and touchscreen, new call speaker) it worked perfectly until a week ago when suddenly the issues occurred.
does anyone (else) has an idea to solve this? Could it be a software issue?
thanks
