Hi all,
Looking for some help with my Desire Z, it suddenly stopped reading any SD cards. I've tried with multiple cards, verified them to be working on other phones.
It's running:
Latest CWM
ROM Manager v4.4.0.7
CoreDroid ROM
Here's the info from the bootloader screen:
I've tried using the:
method to see if that would fix the problem, but fastboot just hangs saying:
I also tried going back to stock using the RUU installer but it reboots the phone to the screen with the silver & black HTC logo, hangs for a bit on the 'Waiting for bootloader.....' message then gives this error:
As well as this my phone does not show up in My Computer & I am unable to set USB mode to Disk Drive as the phone doesn't think it has a card.
Any ideas on what I can do before I bin it and buy a new phone?![Eek! :o :o](/styles/smilies/google/eek.png)
Thanks.
It's running:
Latest CWM
CoreDroid ROM
Code:
VISION PVT ENG S-OFF
HBOOT-0.84.2000 (PC1011000)
MICROP-0425
RADIO-26.02.01.15_M2
eMMC-boot
Sep 8 2010,15:56:38
Code:
fastboot oem enableqxdm 0
and then
fastboot oem eraseconfig
< waiting for device >
ERROR [171]: USB CONNECTION ERROR
The ROM Update Utility cannot connect to your Android phone. Please check that the USB cable is connected properly between the PC and your Android phone.
Thanks.
