AEAllen
I have had no luck finding a Desktop charging/stand for this Ace Plus S7500L.
I bought a couple for other phones (with what looked like the correct charging plug) but the plug did not supply power to the Ace Plus. Must be wired differently than for the Ace Plus. It did have a speaker out jack too.......made for a pad or something.
Anyway, does anyone use a charging/stand/dock for your Ace Plus that works and I can find?
Thanks!
EDIT: Well I modified one that I had with a previous phone and had to fit the plug into the base of the stand for it to go into the phone. Works well and does not look too bad at all. You would think though that someone would come out with nice ones to fit this phone.
Thanks!
