Desktop Launcher
CodeCompany
Do you want to enjoy desktop computer style launcher on your Android? Here is the most fabulous computer style launcher available for your Android (TM) smart phones.
User Friendly Computer Design
Customize your phone with unique look and feel with the fast, clean and energy efficient Launcher. Surprise your friends with computer style look of your Android and also share it with your loved ones.
Built-In File Manager
With built-in File Explore and File Manager you can explore your files and Folders, Copy, Paste, Zip/Unzip, Delete Files, Share Files and can do lot more...
Explore your file system with this simple and efficient file explorer and file manager in native desktop computer design.
Network File Sharing:
Share your files with other users over network. Access your files everywhere over FTP.
Features
- Android applications in Stylish Tiles - In Start Menu
- Best applications are available on One Click - Create Shortcuts of most used applications on Desktop by press and Hold Feature.
- Easy Navigation to the applications
- Built-In File Explorer - Create Folders, Cut, Copy, Paste, Move, Share etc.
- Listing of all of your drives, SD Card, Storage, audio and video files and pictures in PC style.
- put the files to Recycle Bin and delete later
- Built-in ZIP support allows you to decompress or extract ZIP/Unzip files
Enjoy!
https://play.google.com/store/apps/details?id=net.computer.desktop.launcher.file.explorer
Could you explain this clause in the privacy policy for your desktop launcher?
  • Since the application is designed and developed for specific registered users, based on the information we collect through application, our registered users get access to specific information and features.
and also
  • The data received through the application also determines the features i.e. teachers receive data of students of their respective school.
and also
The project started at school to and the users where my students. But now it's public.
Very well done, it's a pretty decent launcher & so far one of the best Windows style launchers on the market.
-Comments
Desktop icons don't reorient with screen orientation.
It would be nice to have the ability the change icon positions on the desktop as well as edit/remove icons throughout the launcher.
Ejeh mentioned orientation lock on the Play Store, that would be useful.
Ad removal.
-Comments
Ad removal.
View attachment 119746 View attachment 119747
Thanks for trying our app.
We are working on a premium version which will contain big surprises
Can't set as the default launcher its pretty much useless as a full-time launcher if it can't do that. Other than that the launcher is smooth and does look nice.
