Accessories Despite searching here, can't find info on STURDY holsters & cases that fit a larger battery...
jws3
Hi, all-
Total newbie here thinking about a DINC to replace a week old Blackberry Bold that I just can't see the screen on or get used to the insufferably tiny keys. Plus, the load time for internet searches on the is best described as "glacial". A friend has the Incredible, which I was impressed with.
After some lengthy searching here & elsewhere I discovered that for my purposes an extended battery is a firm must. Can't have a phone incapable of getting through a day without a recharge.
Problem: I also require a decent protective case AND sturdy, yet attractive holster, both of which accommodate an extended battery, which haven't yet found. I'd like a rubberized soft case that can slide into a secure holster that FIRMLY attaches to one's belt. No wimpy, easily flicked off plastic, thanks. I'd like a good leather case with strong belt clip.
Maybe I am asking for too much. Am I? I don't care if it costs $100, as I can't see a $10 case doing much good.
Any thoughts or ideas? Spent some time searching, but still came up empty.:confused:
Thanks!
No cases for the 2150 battery that Verizon sells.... as of now.
Sedio has a 3500 battery/ back door that they sell and will make a case for it.
This seems to have a possibility, but also gives rise to a question:
droid belt case
Seems to say one can custom make it. You pick the leather, choose a clip or belt loop and can pick other custom options.
What about a magnetic catch? Can one be used on the droid incredible? Some phones don't seem to like magnets, not that I know which is which.
A bit more than the typical $25 junk (might cost $75 or so when done), but quality doesn't come cheap.
Any thoughts or experience with these people apparently based in New Zealand?
