itzdarockz
First off I am not responsible for anything that happens to your phone.
MAKE SURE YOU HAVE AN UPDATED BACKUP FIRST!!!
Bugs:
Texting doesnt work
Calling doesnt work
gps doesnt work
camera doesnt work
Message me if you find any other bugs
Huge thanks to neighborhoodhacker for getting the wifi and sound to work your amazing man.
Release 4 http://dl.dropbox.com/u/8744740/cm-nightly.zip (11-1-12)
Release 3 http://dl.dropbox.com/u/8744740/cm-nightly.zip (10/24/12)
Release 2 http://dl.dropbox.com/u/8744740/cm-nightly (1).zip (10/8/12)
Release 1: http://dl.dropbox.com/u/71816133/cm-nightly-R1.zip (9/30/12)
GAPPS: gapps-gb-20111216-signed.zip
Instructions
1. Download and put on the root of your sd card
2. Reboot into recovery
3. format /cache,/data, and /system
4. flash it and gapps (if you want)
5. go to advanced than fix permissions
6. reboot
Thanks to
cyanogenmod
open source
HUGE thanks to neighborhoodhacker for helping me with this
Master_Key for teaching me some things
samsung transform ultra for their device tree I ported from
Anyone else I forgot
Change log:
Data should now be working thanks to neighborhoodhacker (11-1-12)
Sound is working thanks to neighborhoodhacker (10/24/12)
Wifi is working thanks to neighborhoodhacker (10/8/12)
Built from source with many bugs. It boots! (9/30/12)
Code:
#include <std_disclaimer.h>
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
Bugs:
Texting doesnt work
Calling doesnt work
gps doesnt work
camera doesnt work
Instructions
6. reboot
Thanks to
cyanogenmod
open source
Change log:
