Apps Developing Synchronized Offline Apps using the PhoneGap Sync Plugin
This tutorial covers how to develop an offline sync app using the OpenMobster Sync Plugin for the PhoneGap framework. You can develop your App using HTML5 and Javascript instead of the native programming language.
Features:
  • two way synchronization between the local sqlite database and the corporate backend in the Cloud
  • Offline mode operation. All data changes are tracked and auto synchronized with the Cloud once the connection returns
  • Use of Push notifications to push data changes from the Cloud to the device
  • Support for replicating changes to multiple devices like iCloud does
  • A Java based Channel Framework for integrating your backend with the Cloud
Tutorial: PhoneGapGetStarted - openmobster - Get Started: PhoneGap Sync Plugin - OpenMobster - Open Source Mobile Cloud Platform - Google Project Hosting
Thanks
Sohil
