ryancarolina
Hello,
I apologize if this is not the right section to post this, I looked over the boards and this appeared to be the right spot.
My question is as follows;
I am creating a app that uses WebView to allow customers to use our eTrak webapp through their phones. When browsing to the eTrak url, with in the Java Console you can view eTrak checking the devices/pc OS and then checking for a folder called etrackclient services. Which is located at C:\etrackclient services, for this to work on the phone I need to have the app install the etrackclient services folder on the phone upon installation of the app. On top of that I need to know the exact directory path on the phone, so I can tell etrak where to look when someone attempts to view etrak from their phone.
To sum things up;
1. Can someone provide an example code on how to get apps to install files upon the phone.
2. Can someone show me where apps are saved on a phone and if/how to edit the directory so I can have the app save the files in a certain location.
I thank anyone and everyone for their time reading this and any help you provide.
To sum things up;
