The Gamer Code
My device was accidently formated because of a missread i clicked wipe in twerp and it formated it while trying to format the cache it wiped everything exepet the files how can i recover it all to be like it was before?
well i want my data back so ya my phone does worknandroid backups are your friend. if you have not made one yet then you just need to flash another rom and you are good to go.
i would do some research on twrp. it is a custom recovery that is a tool for root users. it can do many things. one of the main features is the nandroid backup. it is kind of like a save point in a game. so that if you mess up, you can always go back to a particular save point.
but for now hopefully you have a custom rom on your sd card that you can just have twrp flash and you should have a working phone.
well its wiped so your data is lost for good.....at least your phone works.well i want my data back so ya my phone does work
The S6 was manufactured 7 years ago so that's a decent life for a phone. Do you know if the reason was the battery?3 years later it's dead. the device died
