Device freezes
Android device freezes and never goes past the galaxy A520F Android logo screen. I've tried to Wipe out the cache and do factory reset, saw this message "E:Failed to clear BCB message:failed to find /misc partition"
phone's done.....if the partition where the os resides is corrupted and you do not have usb debugging turned on, then there is nothing you can do.
unless:
if you do have usb debugging turned and you can get into fastboot mode you might be able to flash a firmware update from here: https://www.sammobile.com/firmwares/
