Device is rooted problem
I am using android version 6.0.1.
When I try to open certain apps it says your device is rooted and that app wont open on my phone. Any solution for this problem?
i'm curious as to what app says this? usually it is a banking app. i'm also curious as to how you do not know that the device is rooted? did you buy the phone 2nd hand? or brand new? what phone do you have?
I have J3 emerge, I bought brand new phone,
And only few apps show this problem, otherwise 99% apps run smoothly without any problen
The best way to unroot a device is to reflash it with the official firmware. As Ellen Ripley said, it's the only way to be sure. ;)
The vast majority of apps don't care whether it is rooted or not, so only a few complaining tells us very little. If you told us which apps do complain that would tell us more. There are also different ways of checking for root, and it may not need to have root functioning in order to fail some tests.
Along those lines, what is the knox status of the device? I don't own a Samsung, but I think you can check this from the bootloader. If an app were to check the knox "e-fuse" status as a proxy for checking for root that would show whether the system software has ever been tampered with - and as unrooting does not reset the knox flag that would be a problem. However since this is a Samsung-specific thing I'd not expect that many apps to check it.
