Looking for a preferable free bit of software for an android phone that can lock it down so only one application can be used on it and if possible have a username and password login to get to the approved application??
App Locker II is free and all you need to do is lock all your apps except for one so that only that app works. Check it out from the play store.
If you search for app locker, it should be a little bit lower in the list. They tend to list the lockscreen lockers first
