A
Android Question
Guest
It doesn't happen always, but when it happens, it's always when the system is starting, when the apps are starting and being granted root permissions, etc. If I don't do anything, is fine, but If I unlock my screen while the apps are loading on startup and start to open some apps, it reboots(not always). I don't know If it overloads or something, but aLogcat doesn't record anything after the system reboots. I've already used Boot Manager to disable some apps from starting, but the problem persists. It's a Moto X 4.4.4 Stock and I never had this problem before. I belive t's a Xposed Module, but I want to know which one is. I've already did a factory reset, then rooted again, but the problem persists.(before I rooted I wasn't having this problem, this is why I believe it has to do with some Xposed Module or something related to root.)
PS: I will pay you 5 dollars(via Paypal) If you help me and find the problem (what's causing it) via these 2 logs. I know it isn't much, but I want to show some appreciation for helping me.
Here's the kernel message:
https://www.dropbox.com/s/5v9bcbsbqk3z3sq/kernel.pdf
Here's another one that I got right after the reboot happened.(I've waited for the device to start, connected my device to USB, then went to adb and wrote # adb shell dmesg.
https://www.dropbox.com/s/l2ghokfk2w97yv4/Kerneldef.pdf
Thanks.
Thanks.
