snowboarderxd1
Member
Yah I have been trying to theme the devour Since the Day the root came out haha swear i must check this forum every single day haha well here it is my first theme for it.
Inverted Purple
Inverted purple theme is Basicly what it sounds everything is ether purple Or Inverted. I kinda like purple and inverting things was very easy and still looks pretty cool.
what i have themed so far is:
Download Link
MEGAUPLOAD - The leading online storage and file delivery service
To Install the theme you:
1) Launcher ADB
2)change ur Directory to be were your android SDK is
3) Type "adb Devices" Makes sure it says A555 Device under the list of devices
4) Put the framework-res.apk in ur Tools folder in the android SDK
5) Type "adb push framework-res.apk /sdcard/"
6) Type "adb shell"
7) Type "su"
8) Type "mount -o rw,remount /dev/block/mtdblock4 /system"
9) Type "busybox cp -R /sdcard/framework-res.apk /system/framework"
10) Type "reboot" let your phone reboot and Enjoy the black notification bar
IMPORTANT:
If your market doesn't work, for example force closes after you try to download or update a app Just:
Settings>applications>Manage Applications>Market
Then click Clear Cache Then after that Click above that "uninstall Updates"
After that is done your market should work again =D
Ill add more to the list As i remember theme because i probably forgot some other things i changed as well. Im trying to figure out how to change the Clock and Dates font color But i cant see to figure it out. I trying the way with the Service.jar BUT there seems to be Nothing in the service.jar so i cant change it. If anyone finds a way please tell me.
Thank You and enjoy the Theme.
Inverted Purple
- Notification Bar Colour
- Colour of Text in notification Bar (Except Time and Date)
- Download Icons
- Made notification bar see-threw
- Changed downloading icon
- changed bluetooth and Wireless icon
- chaned Battery Now says Percentage inside
- changed website zooming color
- changed all usb connection icon to White to be able to see in new black notification bar
- changed the USB debugging icon
- changed Check Marks and Selection Boxes
Download Link
1) Launcher ADB
6) Type "adb shell"
7) Type "su"
IMPORTANT:
