Help DHD keeps forgettimg my tone settings
RussWWFC
Right, so I am running a DHD, latest update.
Also have LauncherPro plus running, this stops me going to the personalise menu, I have to change everything via settings.
So I've set my message tones/alarm tones/ring tones. They were downloaded by Zedge and are stored in the Zedge directory on the phone. But when I unmount the SD card (IE to look at files on my Macbook) the settings are forgotten and it goes back to default.
The files are on the SD Card and I can set them again, but everytime I mount the card to use as a disk drive it forgets them
Any solution to this?
Anyone? May try flashing a new rom or would it be the SD card. I'm guessing it's a card issue or a sense conflicting with Launcher Pro Issue
I have this similar quirk in my dhd and it always happens when the sd card is unmounted (usb access). But when I mount the SD again either by choosing the default usb charge option, or when I remove the cable, all my ringtones and notifications go back to the customized ones that I've set.
Does your tones still remain at default once the sd is mounted again?
It's weird, some of the time I will get the tone I set, sometimes I will get the default. Generally goes (and stays) wrong after I have unmounted the SD though
Hmmm. My "tones" seem to change at random sometimes. Thought it was a setting I hadn't got right but I'm not so sure. Can't get a handle on when/why yet though.
Dave
