Help DHD Weather widget issue
Darhan76
Hello people..
My phone is normal DHD it was not rooted, and I have never experienced any problem with it since i got it in March.
I upgrade my DHD with Gingerbread, everything was OK, however since 8 of June my weather widget (HTC Sence) stoped updating.
It shows the last meteo data since last update ( 8 June ).
I was trying to restart it but unfortunatly it does not help.
Anyone experienced the same?
Any suggestions are welcome...
Thanks!!!
Is it set to sync via the account and sync menu?
I dont really now how it is set to sync..I choose to sync every 3 hours and every time I open the widget...
Sorry, does it make any difference how to sync? I thought it is enough just to tap the widget and particullary update, and it should work..
Thanks..
I was just trying to rule out whether the update had messed up the sync settings.
You've restarted, have you cleared the cache and data via the apps menu?
It's a stock widget app, so you can't reinstall.
Factory reset?
Is it just your location or all of them? Can you remove and re add your current location?
Factory reset?
All of them.. I cannot remove my current location Others yes but local no..It gives u a message Connection error, sorry your connection is dropped down..( I have perfect connection)
Perform factory reset and still nothing:confused::confused::confused:
Anyway thank you for your concern
